1230 Discussions
Intel NUC5CPYH and Windows 8 Embedded standard x64
Hello
I'm struggling to successfully install Windows 8 Embedded standard onto an intel nuc5cpyh.
The drivers supplied here
https://downloadcenter.intel.com/product/85254/Intel-NUC-Kit-NUC5CPYH https://downloadcenter.intel.com/product/85254/Intel-NUC-Kit-NUC5CPYH
are not all supplied in .inf format which the Windows 8 embedded IBW requires.
I've tried installing Windows 8.1 enterprise x64, installed drand then used driver magician (link below) to capture the drivers onto usb stick. This seems to work (at least it detected drivers and installed windows)
http://www.drivermagician.com/ Device driver backup, restoration, update and removal tool for Windows, drivers backup, backup drivers
However, the key problem is that when Windows embedded x64 finishes installing, the USB drivers don't seem to work and hence we can't get any further due to not being able to use the keyboard or mouse!
There is a similar issue on this thread:
https://communities.intel.com/thread/77220
We've also tried this thread to see if we can get it working, but the USB seems completely unresponsive.
http://codeabitwiser.com/2014/03/how-to-install-windows-7-with-only-usb-3-0-ports/ http://codeabitwiser.com/2014/03/how-to-install-windows-7-with-only-usb-3-0-ports/
Perhaps it is because the 8.1 x64 USB3.0 drivers are different to 8.0 standard drivers?
CarlosAM_INTEL
Hello SpiderGroup,
Thank you for contacting the Intel Embedded Community.
Reviewing your previous communication, it is important to clarify you that the consultations related to Intel NUC products should be addressed to the channel specialized on them, which is the same where the mentioned thread has been posted.
This channel is the https://communities.intel.com/community/tech/nuc Intel(R) NUC Forum, where we suggest you to address any question of this kind.
We hope that this information is useful to you.
Carlos_A.
