Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1227 Discussions
Issue with IEGD version > 8 and WinCE 5
NMach
Hi!
We have been using the Intel IEGD display driver version 6 for a while for our 855GME chipset on Windows CE 5. Because we would like to support the 945GSE chipset in our image we have upgraded the IEGD driver to version 8 which should support both chipsets.
We are running an application which creates data reports in bitmap format. The application is using the Wince IImagingFactory to accomplish this. We noticed that with version 8 we are missing a lot of data in our reports. There seems to be missing a lot of data in theses images.
This is a screenshot of a report with IEGD version 6:
And this a screenshot of a report with IEGD 8:
Does someone have any idea what is going wrong?
Are there some changes between these versions which could explain this behavior?
I have also tried the latest version of IEGD ( 10.3 ) but it has the same issue ( even worse ).
Ciao
NMach
Hi Kirk,
Do you have access to eHelp again?
