1228 Discussions
J1900 motherboard and POSReady 2009
PWill11
We're evaluating a J1900 system to be used as a Point-of-Service/Sale appliance. I have built and tested the mbd using POSReady 7 O/S. When I try to build a POSReady 2009 image w/ the Microsoft OEM DVD, the installation blue screens 2 minutes into the build process. Is Bay Trail incompatible w/ POSReady 2009?
Paul
Gabriel_T_Intel
Hello PaulW.
We are continuing to look into this request, We will reply again soon when we have information for you.
Regards.
Gabriel Thomas.
Gabriel_T_Intel
Hello Paul W.
The POSReady 2009 is built on the windows XP base, so the applications that are compatible with Windows XP should run without a problem
on POSReady 2009, but unfortunately this OS is not supported/validated for the Bay Trail J1900 Platform.
I Hope this information is useful to you. If you have any other question, we will be more than glad to assist you.
Regards.
Gabriel Thomas
Adolfo_S_Intel
Hello PaulW
As Gabriel told you POSReady 2009 is not supported by Intel® for this platform, in the following table you can check the supported Operative Systems
Our recommendation for you would be to use Windows Embedded Industry, or WE POSReady 7.
Adolfo.
OK guys, thanks for the info/confirmation. I will inform our dev. manager to drop POSReady 2009 from the specifications.
Paul
