1249 Discussions
Latest WEC7 BSP and EMGD for E3800 (Where to find???)
BHick4
I am looking for the latest WEC7 MR3.1 BSP and the EMGD video driver as referenced in the attached pdf release notes that have recently been released by Intel.
Could anyone point me to a link to where to download these? Adeneo and BSQuare do not have these posted. Adeneo only has the MR2 release which was from back in March and their EMGD driver is even older. There have been two releases since March 2015. There is a July 2015 MR3 and August 2015 MR3.1.
Also from my understanding there is a new EMGD driver as referenced in the attached release notes. (Intel_BYT_WEC7_EMGD_v36.16.3_RC_2015-07-02_3000.zip)
There is also another file referenced in the release notes. IO Driver (Intel® Processor WEC IO BSP.msi )
If necessary my company also has an elevated Intel Permissions Account but for whatever reason I have to use a separate account to access this forum.
Brian
CarlosAM_INTEL
Hello Brian,
The Windows Embedded Compact 7 (WEC7) MR3.1 Board Support Package (BSP) and Intel(R) Bay Trail WEC7 Embedded Media and Graphics Driver (EMGD) v36.16.3 are unavailable to be released at this moment because they are available in Beta version, which is only for Intel internal use.
A Corporate Non-Disclosure Agreement (CNDA) is required to obtain them when the next version will be released, because they are categorized as Intel Confidential. A CNDA is between a company and Intel. More CNDA information can be found at the following web site:
https://supplier.intel.com/static/misc/CNDAterms.htm https://supplier.intel.com/static/misc/CNDAterms.htm
Finally, please update your Embedded Design Center (EDC) account to Privileged type. To request an upgrade from your Basic EDC account to a Privileged account, go to http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html and click on "Manage Your Intel Profile" found in the "Manage Your Account" section of the page. From there you can request an upgrade. After you submit the application, please let me know and I will expedite the review of your application. The application can be found at:
https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html
Please let us know if this information is useful to you.
Carlos A.
BHick4
Hi Carlos,
My company already has a CNDA with Intel but it is tied to another email account. Could you give me a call so that we do not have to discuss this publicly in the forum. If not can you give me a direct email way to communicate with you.
Brian
Gabriel_T_Intel
Hello Brian,
We will contact you by email, thanks.
Gabriel Thomas
Hello, Brian! In order to supply you with Intel Confidential content, your account needs to be upgraded from Basic to Privileged. Your company does indeed have a CNDA with Intel so approving your request to upgrade will take no time at all. I will have mailto:edc.support@intel.com EDC Support contact you to get this done.
Thanks!
-Scott
BHick4
I have not been contacted by EDC Support. Could someone please have them contact me? This issue is urgent!!
BHick4
My account has now been modified to privileged. Where can I find the latest WEC7 MR3.1 BSP and the EMGD video driver.
Brian
CarlosAM_INTEL
Hello Brian,
We will contact you via email to help you.
Carlos A.
BHick4
Either ours or your email server stripped the setup file out of the zip that you emailed. Could you provide a download link? or I can provide a place to upload. Also would it be possible to get this file referenced in the Release notes above. (Intel_BYT_WEC7_EMGD_v36.16.3_RC_2015-07-02_3000.zip)
CarlosAM_INTEL
Hello Brian,
Carlos A.
BHick4
Hi Carlos,
Your email server is still removing files from the zips even after you rename them to .txt. Could you please try resending the zips with password protection and renamed? The server seems to be smart enough to dig into the files even when the extension is changed but adding the password should prevent the server from interfering.
Brian
BHick4
Hi Carlos,
I successfully received the BSP but I have only received files 1 of 5 and 5 of 5 for the EMGD. Please send or resend the rest.
Brian
BHick4
Hi Carlos,
I have still not received all 5 of the zip files for the EMGD and some of the files that I did receive are corrupt. Please use this link to upload the files to me. You will need to use the same password that you have been using for the zip files. https://parkerhannifin.box.com/s/lvg7mk3ghj28jon35hyrg6or0mhsyw03 https://parkerhannifin.box.com/s/lvg7mk3ghj28jon35hyrg6or0mhsyw03
Brian
BHick4
Brian Hicks Aug 13, 2015 6:57 AM (/message/13149# 13210 in response to Brian Hicks)
Hi Carlos,
Brian
BHick4
Hi Gabriel,
Yes I did receive the first email with the BSP for WEC and it did work successfully. I now just need the second folder "Intel Embedded Media and Graphics Drivers (Intel(R) EMGD)
Brian
Gabriel_T_Intel
Hi Brian,
Thanks for the update.
I have sent you two emails. The Intel Embedded Media and Graphics Drivers (Intel(R) EMGD) has four folders:
First email:
1.Intel_BYT_WEC13_DXSHOW_V36.18.3_RC_2015-07-06_3000
2. Intel_BYT_WEC13_EMGD_V36.18.3_RC_2015-07-06_3000
Second email:
3. Intel_BYT_WEC7_DXSHOW_V36.16.3_RC_2015-07-06_3000
4. Intel_BYT_WEC13_EMGD_V36.18.3_RC_2015-07-06_3000
Gabriel Thomas
BHick4
Hi Gabriel,
I have not received your emails. They must be getting blocked. I have checked our servers quarantine and they are not there so I suspect it is Intel's server.
Brian
Gabriel_T_Intel
Brian,
I sent you four emails, lets try one file/email.
Please let me know if you still have issues receiving these folders.
Gabriel Thomas
BHick4
Hi Gabriel,
Your server is still digging into the zip files and removing .dll and .exe files. Even if you change the extension it still does it. What you need to do is zip each of the attachments with a zip password. Make the password "password".
Brian
CarlosAM_INTEL
Hello Brian,
Carlos A.
BHick4
Hi Carlos,
The link says I am unauthorized to access.
Brian
