Linux graphic artifact IEGD 10.3
RHane
I'm new to the community, and first, thank you to Intel to give us the helpfull IEGD tool.
But I have got a problem with IEGD 10.3.1.
When I switched from one virtual terminal to another (with CTRL+ALT+Fx), I have got graphical artifacts and freeze.
I'm working on a Intel Atom D510. Do you know if there is a solution to this problem?
Thank you!
RHane
Ok, I've tried with 3 differents kernels (2.6.31.13; 2.6.33 and 2.6.34) and there is no difference.
I've also founded that you can start once the X server, and after killing it, you're not able to start it a second time.
Can someone help me?
FMcNu1
Valued Contributor I
Hi Rhanesse:
I know that we have some Intel folks looking into your message so hopefully you will hear something soon. In the meantime, any further details describing the failure you can provide might be helpful.
Thanks for your patience
Felix
szhuo
I used to have the same problem, but it works well with kernel 2.6.34 now, I think you need a patch.
--- agp/drv_cmn.c 2010-06-29 11:26:51.568770776 +0800+++ ../../iegd_10.3.1/agp/drv_cmn.c 2009-12-02 01:32:55.000000000 +0800@@ -506,9 +506,7 @@ static AGP_MEM_TYPE i8xx_alloc_pages(size_t pg_count, unsigned int order) { struct page * page;-# if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,31)- int i = 0;-# endif+ AGN_DEBUG("Enter"); page = alloc_pages(GFP_KERNEL, order);@@ -532,13 +530,7 @@ * because of the changes in page fault handler in the kernel. */ AGP_LOCK_PAGE(page);-# if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,31)- for (i = 0; i < pg_count; i++) {-# endif atomic_inc(&agp_bridge->current_memory_agp);-# if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,31)- }-# endif return PAGE_ADDRESS(page); //returns page or addr depending on kernel AGN_DEBUG("Exit");@@ -567,6 +559,7 @@ free_pages((unsigned long)addr, order); atomic_dec(&agp_bridge->current_memory_agp);
AGN_DEBUG("Exit"); }
