MTTF / FIT rate for E3940
could anyone pls. provide the MTTF / FIT rate for the processor E3940?
Many thanks and best regards,
Dominik
CarlosAM_INTEL
Hello, Dominik76 :
The information that may help you should be requested by filling out the https://qdms.intel.com/Support/Support-IntelQDMS.aspx Submit a QDMS Support Request form.
It is important to let you know that the Failures in Time (FIT) is a standard industry value defined as the Failure Rate (λ) per billion hours. It can be expressed as:
FIT = λFIT = λhours ×109
By the way, the Mean Time to Failure (MTTF) is another standard industry value which provides the average time to failure of non-repairable devices. It can be calculated using the following formula:
MTTF hours = 1 / λ hours
We hope that this information may help you.
Carlos_A.
CarlosAM_INTEL
Hello, Dominik76 :
Carlos_A.
