1249 Discussions
Need recommendations for an embedded board
asisc
I have a project that requires a Atom N270 or better type processor board with the following:
- must run Linux
- needs a single USB port
- needs LVDS LCD interface
- needs Ethernet
- needs sata or ide interface
- smaller than mini-itx (pico-itx?)
- audio out is a plus but not required
- fanless if possible but not required
Does not need:
- any type of expansion slots
- power management
- video out
- serial/parr ports
- wireless
- PS/2 ports
- I'm not locked into Atom if you have something else.
Any companies that monitor this board that might have recommendations from
stock or a custom board or anyone else? Searching on the web finds lots of off the shelf
mini-itx boards but seems like I'm not having any luck finding exactly what I want.
FMcNu1
Valued Contributor I
Hi avsys:
Welcome to the lntel® Embedded Community.
Have you looked at the Solutions Directory for the lntel® Embedded Alliance? Here you will find Intel-based products from over 160 companies within Intel's trusted embedded ecosystem. There are many board-level products in all of the popular form factors. From the specifications you stated, I think there is a high probability you will find what you need.
Find it here: http://www.intelcommsalliance.com/kshowcase/view http://www.intelcommsalliance.com/kshowcase/view" target="_self" rel="nofollow">http://www.intelcommsalliance.com/kshowcase/view
Hope this helps
Felix
asisc
Thanks for the link, I'll check it out.
One of the problems I've run into searching web sites is once I find something close I
have a difficult time gettting a response to my inquiry and answers to questions. I was
hoping a post here would find some vendors that have what we need and would
establish contact. Or maybe find someone else who has used a vendor that would
offer some ideas.
