1267 Discussions
Performance problem with a Skia application
Haase_J
We use two different Intel CPUs. On the system with an Intel Atom E3940 / 8 GB RAM and a Windows 10 IoT Enterprise LTSC 2021, the application runs as expected. If we run it on an Intel Celeron 3965U / 8GB RAM and a Windows 10 IoT Enterprise LTSC 2021, the processor load increases to 50%. It is assumed that the CPU is not being utilised on the Celeron system. How can you see if the support is really running or being used? The application is opened in a Microsoft Edge > V120.xxx.
I would be grateful if you could help me find out where else I can look to solve the problem.
With kind regards
Jens
Earl_Intel
Hello Haase_J,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Embedded Communities Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Earl E.
Diego_INTEL
Hello @Haase_J,
Just to let you know, Apollo Lake and Kaby Lake are not being actively supported anymore.
https://www.intel.com/content/www/us/en/support/articles/000022396/processors.html
I was looking internally but we don't have much information regarding Skia.
Looking at the processors, one is 4 cores and the other one 2, it may be influencing in the load as you are seeing it. I think you may try checking in the Task Manager the CPU performance and compare when you run the application if there is any change.
Also, as you are running it in Edge, you may try using another browser to check if there is any difference for good.
@Diego_INTEL
