1230 Discussions
Spread Spectrum on LVDS in atom D525
acoll5
Hi all,
we are using an industrial board based on D525 Atom.
We installed Windows Embedded Standard 7 as OS and the Intel® Graphics Media Accelerator
Production Version 15.12.75.50.7.2230 for the graphics controller.
We tested the board for Radiated Emissions and we found a lot of noise coming from graphics adapter.
We then compile the IEGD driver enabling the spread spectrum clocking attributes on LVDS port and the noise reduces a lot.
Now, we know that IEGD is not compatible with WES7 and indeed we got some Blue Screens (for example if we try to use rdp
protocol for remote connection).
Is it possible to have the same clocking configuration ore something similat with the "standard driver" changing the windows registry or in any other way?
Andrea
Kirk_B_Intel
Running the XPDM driver on WES7 is definitely a "legal" option, however, if you have an application (like remote desktop) it may require a WDDM driver to operate which might exaplin the RDP blue screen- poor testing by MS for legal display driver options.
To change GMA, you need to make changes to the VBIOS image in the BIOS image on the board. That uses a utility called 'BMP" to change options like spread spectrum operation that generally is only available to OEMs (I do not know your customer status). Additionally this capability usually requires close work with your BIOS vendor to get the appropirate merge tools for their product.
As you have found, the IEGD driver allows you to make these sorts of tweaks much easier, but primarily for a more embedded envirionment that the GMA drivers do not want to provide as it tends to mess up WHQL compliance, and is dangerous to put into end-user laptop / desktop users hands.
To adjust spread spectrum, you may be better off figuring out how to use the IEMGD driver...
Hope this helps.
