1262 Discussions
Sps Flash Image Tool (FITc) Requirements
ahmetf
Hi, I have an intel atom C3758 base costum design board.  It runs OpenBSD or Yocto project as an operating system on the board. There are hang problems on the device. The device sometimes opens without any problems and hangs after a certain period of time, and sometimes it hangs in the opening part on both operating systems. I create and configure a complete SPI image file for harcuvar platform on Sps Flash Image Tool(spsFitc) and programing it with flash programmer device. I have a few questions about settings.
1- In the Flash layout->Regions section, there is Descriptor Region. Where can I find "OEM Section Binary" or how can I create the binary file for ?
2-  In Intel(R) ME Region, there are two binary files are needed; spsRecovery and spsOperational. In tool folder (SPS_SoC-A_04.00.04.600.0) these files are available. Are these files suitable for the c3758 processor and harcuvar platform? If not, where can I find suitable ones?
LinuxBIOS : Coreboot 4.16
Payload : SeaBIOS 1.16
My Spi Flash : Winbond W25Q128JV ( 16MB, only one component
Diego_INTEL
Hello @ahmetf,
As I remember, the OEM section just can be ignored, there should be an option to not include it.
Thanks for sharing to the community.
@Diego_INTEL
Diego_INTEL
Hello @ahmetf,
For the OEM section, as the name implies, the original equipment manufacturer section is established by the manufacturer.
As I understand, this tool is not restricted to a specific processor.
To get access to the respective documentation and tools you need to update your account to the premier option. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/developer/premier-registration.html
@Diego_INTEL
ahmetf
Hello Diego,
After contacting the manufacturer, the answer they gave me was as follows;  We are memory supplier, there is no code inside.The code is from end user or our customer, please contact the supplier of the board.
After my own research, I found my own answer. I leave the link below for those who will encounter this problem.
https://designintools.intel.com/product_p/stlgrn49.htm
Diego_INTEL
Hello @ahmetf,
@Diego_INTEL
