1266 Discussions
US15W - Bios Release Notes Clarification
RDool1
I would like to have some more clarification on this note.
From the bios release notes for the Poulsbo, you can see that for the latest bios, there is a section where it says that:"S3 is not supported by processor" (See attached Picture)
http://edc.intel.com/Download.aspx?id=1150&returnurl=/Platforms/Atom-Z5xx/default.aspx http://edc.intel.com/Download.aspx?id=1150&returnurl=/Platforms/Atom-Z5xx/default.aspx" rel="nofollow" target="_blank">http://edc.intel.com/Download.aspx?id=1150&returnurl=/Platforms/Atom-Z5xx/default.aspx
Now if you check the Atom Design Guide Doc ID# 364622, Table 86 & 87 confirms that S3 is supported.
Is this a mistake? I would appreciate if you could clarify this point.
Thank you for your assistance.
Kind Regards,Aryan.
FMcNu1
Valued Contributor I
Hello Aryan:
Since your question is about Atom and US15W, I thought I would make you aware of the Intel® e-Help Desk. This is a special place for support that is staffed by Intel representatives reaady to answer your technical questions.
e-Help is only available to community users with Privileged account status. I can see that you are already a Privileged user so you may access e-Help immediately.
Check it out here:
http://embedded.communities.intel.com/community/intel_e-help_desk/low_power_platforms http://embedded.communities.intel.com/community/intel_e-help_desk/low_power_platforms" target="_blank" rel="nofollow">http://embedded.communities.intel.com/community/intel_e-help_desk/low_power_platforms
Felix
FMcNu1
Hello Aryan:
Check it out here:
Felix
