braswell sio spi not enabled
sbass
On braswell, i want use sio spi:
-- My configuration:
Gpio Multiplexing:
179 V14 SPI1_CLK 1 SPI1_CLK V1P8A 0 (20k PU) 0
180 Y13 SPI1_CS0_N 1 SPI1_CS0_N V1P8A 1 (20k PU) 1
181 Y12 SPI1_CS1_N 1 SPI1_CS1_N V1P8A 1 (20k PU) 1
182 V13 SPI1_MISO 1 SPI1_MISO V1P8A Input (20k PU) Input (20k PD)
183 V12 SPI1_MOSI 1 SPI1_MOSI V1P8A 0 (20k PU) 0
I used mode 1.
In device tree of coreboot:
register "lpss_acpi_mode" = "0" device pci 1e.5 on end # 8086 228e - SPI 1 device pci 1e.6 on end # 8086 2290 - SPI 2 device pci 1e.7 on end # 8086 22ac - SPI 3
-- In coreboot trace:
src/soc/intel/braswell/chip.c/enable_dev ( Intel Braswell SoC ), type: 2
vendor: 0xffff. device: 0xffff
class: 0xff Unassigned class
subclass: 0xff ???
prog: 0xff
revision: 0xff
src/soc/intel/braswell/southcluster.c/southcluster_enable_dev ( Intel Braswell SoC )
PCI: Static device PCI: 00:1e.5 not found, disabling it.
-- In kernel:
# lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register [8086:2280] (rev 35)
00:02.0 VGA compatible controller [0300]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller [8086:22b1] (rev 35)
00:0b.0 Signal processing controller [1180]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller [8086:22dc] (rev 35)
00:14.0 USB controller [0c03]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller [8086:22b5] (rev 35)
00:18.0 DMA controller [0801]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 DMA Controller [8086:22c0] (rev 35)
00:18.1 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 1 [8086:22c1] (rev 35)
00:18.2 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 2 [8086:22c2] (rev 35)
00:18.3 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 3 [8086:22c3] (rev 35)
00:18.4 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 4 [8086:22c4] (rev 35)
00:18.5 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 5 [8086:22c5] (rev 35)
00:18.6 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 6 [8086:22c6] (rev 35)
00:18.7 Serial bus controller [0c80]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO2 I2C Controller # 7 [8086:22c7] (rev 35)
00:1b.0 Audio device [0403]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller [8086:2284] (rev 35)
00:1c.0 PCI bridge [0604]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port # 1 [8086:22c8] (rev 35)
00:1c.1 PCI bridge [0604]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port # 2 [8086:22ca] (rev 35)
00:1e.0 DMA controller [0801]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO1 DMA Controller [8086:2286] (rev 35)
00:1e.3 Communication controller [0780]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO1 HSUART Controller # 1 [8086:228a] (rev 35)
00:1e.4 Communication controller [0780]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series LPIO1 HSUART Controller # 2 [8086:228c] (rev 35)
00:1f.0 ISA bridge [0601]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU [8086:229c] (rev 35)
00:1f.3 SMBus [0c05]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Controller [8086:2292] (rev 35)
01:00.0 Non-VGA unclassified device [0000]: Altera Corporation Device [1172:e003] (rev 01)
02:00.0 Ethernet controller [0200]: Intel Corporation I210 Gigabit Network Connection [8086:1533] (rev 03)
In coreboot spi device not found and in kernel, It is the same.
All other device SIO are available, as i2c or hsuart, why spi is disabled ? how to enable spi ?
CarlosAM_INTEL
Hello, keziaha:
It is unclear for us the meaning of the acronym SIO. In case that it refers to Serial IO, we suggest you as a reference verify that your implementation fulfills with requirements stated in the section called Serial IO 2 of the https://mail.coreboot.org/pipermail/coreboot-gerrit/2015-May/026108.html Patch set updated for coreboot: 14ae5d4 DO NOT MERGE: Braswell: Add Braswell SOC support and https://github.com/coreboot/coreboot/blob/master/src/soc/intel/braswell/include/soc/pci_devs.h coreboot/pci_devs.h at master.
It is important to let you know that the coreboot consultations should be addressed as a reference as well at the channels listed in the https://www.coreboot.org/consulting.html coreboot consulting services website.
We hope that this information may help you.
Carlos_A.
sbass
In document Number: 555139 iotg_brasswell_design
Device and I/O Support Matrix
SIO SPI --> TBD ( for linux/yocto)
TBD is defined now ?
all braswell series support sio spi device ? my reference is N3160 ?
CarlosAM_INTEL
Hello, keziaha:
Thanks for your reply.
The information that you have mentioned is the latest and apply for all the Braswell devices.
We hope that this information may clarify this situation.
Carlos_A.
sbass
On old generation cpu baytrail: Fsp header file(fspvpd.h) contains :
UINT8 PcdEnableSpi; /* Offset 0x002B */
Not available on braswell, why ?
package fsp for braswell: BSW_FSP_KIT_MR1.tgz provided by intel.
FSP header file is an input for fspsiliconinit(),fspsiliconinit must activate pci device as SPI
Best Regards
Sébastien
CarlosAM_INTEL
Hello, keziaha:
Thanks for your update.
In order to help you, we will contact you via email.
Carlos_A.
