1263 Discussions
how to control Atom C3558 GPIO under Linux?
wolfsu
HW use GPIO[5] pin(output of C3558) connected to an input pin of WiFi chip to pull high/low on this pin.
What Linux driver or kernel module should I use to control this GPIO?
There is only 1 gpiochip508 in my sys-fs as below, but it seems to be used for UART to USB control:
$ ll /sys/class/gpio/
total 0
drwxr-xr-x 2 root root 0 Dec 11 09:41 ./
drwxr-xr-x 68 root root 0 Dec 11 09:41 ../
--w------- 1 root root 4096 Dec 11 09:41 export
lrwxrwxrwx 1 root root 0 Dec 11 09:41 gpiochip508 -> ../../devices/pci0000:00/0000:00:15.0/usb1/1-3/1-3:1.0/gpio/gpiochip508/
--w------- 1 root root 4096 Dec 11 09:41 unexport
$ lspci -s 00:15.0
00:15.0 USB controller: Intel Corporation Atom Processor C3000 Series USB 3.0 xHCI Controller (rev 11)
$ cat /sys/class/gpio/gpiochip508/label
cp210x
CarlosAM_INTEL
Hello, @wolfsu:
You should address this type of questions as a reference to the channel listed on the following website:
https://01.org/community
@CarlosAM_INTEL.
wolfsu
Hi
Sorry! Do you mean I have to create a new account on https://01.org/community , and repeat my question again? If yes, which channel should I use?
Wolf
CarlosAM_INTEL
Hello, @wolfsu:
Thanks for your reply.
Your answer to your last communication should be obtained by filling out as a reference to the following form:
https://01.org/about/contact-us
@CarlosAM_INTEL
wolfsu
