1229 Discussions
uart real com1 can not be opened by windows 10 putty
ear
Please, help.
we have developed a new shopping system based on UP CORE PLUS board (Intel® Atom™ x5 / x7 64 bits). The windows 10 device manager presents the UART COM ports and the virtual COM ports perfectly, no errors. We use a monitoring software, like Device Monitoring Studio or MObaxterm (minicom engine), to display data, and it works fine displaying data from real and virtual ports. But we need to interact with the real COM1 UART port using Python (pyserial), but it doesn't work, the port doesn't open. Using PUTTY windows, the problem is the same, it does not work when trying to open the real port, and the error code is 87. The virtual ports can be open witout problems. We think Python works when Putty does.
The issue is in windows 10 (home or pro tested). When the systems runs in ubuntu 20.04, the real ports UARTs  and the virtual ports work fine, all of them  (tested by cutecom).
We think there is a a driver problem. We have the latest UART drivers intalled:
serial-io-30.100.1631.03-win10-rs1-rx64-apl-signed-installer
Intel_Processor_Win10_HSUART_Sub_Drivers_64Bit
Please, we would appreciate any help
EAR SYSTEMS
CarlosAM_INTEL
Hello, @ear:
You should run the tool stated in the following website that may help you:
https://www.intel.com/content/www/us/en/download-center/home.html
@CarlosAM_INTEL.
ear
Thanks Carlos for your quick answer.
We run that tool before. The drivers are all the latest.
Any way, we will do it again and tell you...
ear
Carlos,
the Intel driver and support assistant tell us again that everything is updated in windows 10 pro for workstation (home versión tested before and the same issue)
Any help?
thanks
CarlosAM_INTEL
Hello, @ear:
Thanks for your reply.
We want to address the following questions to understand this situation:
Could you please clarify how many of the affected designs have been manufactured, how many are related to this situation, and the failure rate information?
Could you please let us know the part numbers of the processors related to this thread?
Could you please list the sources that you have used to develop the affected designs?
Could you please clarify if the designs have been verified by Intel?
We are waiting for your answer.
@CarlosAM_INTEL.
ear
Hi again, here you hace your answers:
We are in a prototype fase, 2 identical windows 10 systems have been created, and both have the same issue. (windows 10 pro and home)
The windows 10 device manager presents the UART COM ports and the virtual COM ports perfectly, no errors. We use a monitoring software, like Device Monitoring Studio or MObaxterm (minicom engine), to display data, and they work fine displaying data from real and virtual ports. But we need to interact with the real COM1 UART port using Python (pyserial), but it doesn't work, the port doesn't open. Using PUTTY windows, the problem is the same, it does not work when trying to open the real port, and the error code is 87. The virtual ports can be open witout problems. We think Python works when Putty does. We have tried updating drivers, changing windows 10 version...
Could you please clarify if the designs have been verified by Intel?  The board is UP CORE PLUS, by AAEON, so we think so.
https://up-board.org/wp-content/uploads/datasheets/Data-sheet-UP-Core-Plus.pdf
thanks
CarlosAM_INTEL
Hello, @ear:
We suggest addressing your questions related to the cited third-party device as a reference through the channel listed on the following website:
https://forum.up-community.org/?utm_source=up-board_homepage&utm_medium=web&utm_campaign=community_askforum_upboard
@CarlosAM_INTEL.
ear
CarlosAM_INTEL
Hello, @ear:
Thanks for your update.
We suggest keeping in touch with them because they have the information to give you the proper support with this third-party implementation.
@CarlosAM_INTEL.
