Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
82574 eeprom programming
LOxle
With regard to the 82574 GbE Controller. In Ver2.2 of the datasheet there was mention
of eeupdate.exe to program the configuration eeprom. In Ver2.7, that paragraph was removed. I wanted a utility to do the eeprom programming. I found eeupdate.exe v5.01.01.08 on the web, but this does not find the device. I have IDadapt.exe v1.06.07.00 and diags.exe v1.14.69.00 which both find the device and produce correct results. Question: Is there a later version of eeupdate.exe, and where can I get it ?
