Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
82580 SGMII
AMois
Hi, you make the dress based on the 82580.
2 ports internal MAC, 2 ports are connected by a sgmii 88E1112 -> 100base-FХ.
for MDI compound is. The status register 88e1112 connection and synchronization SGMII there. 82580 No link
Please help configure eeprom
CarlosAM_INTEL
Hello Moiseev,
Thank you for contacting the Intel Embedded Community.
The information that may help you is stated on the answers to the questions 6, 8, 9, 11, and 26 of the http://www.intel.com/content/dam/www/public/us/en/documents/faqs/82580eb-82580db-gbe-lan-controller-faq.pdf Intel(R) 82580EB/82580DB GbE LAN Controller Frequently Asked Questions (FAQs).
Please let us know if this information is useful to you.
Carlos_A.
AMois
Thanks for the advice. I read all.
I tried to write to eeprom 82580_4_SGMII_PHY_MDIO_No_Mng_3.29.bin
lanconf in ports 2 and 3 worked on reception and transmission in the "ignore the link", when the inserted optical fiber from the receiver to the transmitter.
I tried to write to eeprom 82580_4_Copper_SMBUS_3.29
fully working ports 0 and 1
it is impossible to combine the two into one firmware
it is not clear how a URL "CSR Auto Configuration Structure Format". eg operating eeprom:
0003 0023 0D64 FF80 FFFF
0003 - the number of words
0023 - CRC8
0d64 (640d) - ????? address
ff80-data
ffff-data
register with this address is not found in the datasheet
AMois
Device ID
Port 0 = 150E (link mode = 00b = MAC operates with internal copper PHY (10/100/1000Base-T))
Port 1 = 150E (link mode = 00b = MAC operates with internal copper PHY (10/100/1000Base-T))
Port 2 = 1511 (link mode = 10b = MAC and SerDes operate in SGMII mode.)
Port 3 = 1511 (link mode = 10b = MAC and SerDes operate in SGMII mode.)
CarlosAM_INTEL
Hello Moiseev,
Thanks for your replies.
In order to help you, we will contact you via email.
Carlos_A.
