Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
82599 EEPROM data files location
PWilc1
Dear All,
I have been unable to locate EEPROM data files for the 82599 part on the Intel web site.
Does anyone have a link to these?
Thanks, Paul.
Gabriel_T_Intel
Hello Paul,
Please check the document number 425136 - http://www.intel.com/cd/edesign/library/asmo-na/eng/425136.htm Intel® 82599 10 Gigabit Ethernet Controller – EEPROM Images – Rev. 4.40, it contains the EEPROM images.
This document is available in https://businessportal.intel.com/irj/portal Intel Business Portal, (IBL).
Please let us know if you are able to download this file.
Gabriel Thomas
Gabriel_T_Intel
Hello Paul,
Welcome to the Intel Embedded Community.
We are checking your case and we will contact you as soon as possible with additional information.
Gabriel Thomas.
Gabriel_T_Intel
Hello Paul,
Gabriel Thomas
PWilc1
Dear Gabriel,
I got the ZIPped files successfully. The included 82599_4 40_EEPROM_readme.pdf
has no explicit mention of the 82599ES. Can I assume that the 82599_XAUI_NO_MNG_4.40
file, for example, will work on both the JL82599ES and the JL82599EN?
I did try the design review link, but it said I needed "privileged access", which I thought
I already had. I did go through the application process to get it. I believe we already have
the NDA signed and in place.
Thanks, Paul.
SThar1
Hi Pwilc,
I'm quite new to 82599 ethernet controller. We are going to develop a bypass card using 82599. Do you have any resources which are helpful ?
I want to know why is there a EEPROM and is there any image to download for EEPROM and 82599 iteself and how it can be configured using PC through PCI port ( Does it communicate through SMBUS ? )
Your reply is highly appreciated.
Supun.
CarlosAM_INTEL
Hello, @SThar1​:
Could you please confirm if your previous communication is the same stated in the following forum?
https://forums.intel.com/s/question/0D50P00004TSd4ASAT/design-resources-for-82599
We are waiting for your clarification.
@Mæcenas_INTEL​.
