Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
AMI BIOS Check Point F0
OXue
Hi:
Platform: Napa, U7500+945GME+ICH7M
BIOS Vendor: AMI
Power Supply: All of powers(+5VAL(+5VS)、+3.3VAL(+3.3S)、+2.5V、+1.5V、+1.05V、+1.8V、+0.9V、+VCore) come from +5V
Issue: This system works abnormal during POST. The Check Point is F0. that shows the BIOS determines that a BIOS recovery needs to occur because the user
has forced the update or the BIOS cheksun is corrupt. Enclosed is the feedback information from BIOS. Can you help me>? thanks you .
BRich9
Ocean:
This checkpoint is associated with the recovery procedure. Did you try to flash a new BIOS over the original CRB BIOS on the Napa platform?
Thanks ... br
OXue
Hi Brain:
Thanks for your reply. Have you check out the file enclosed? The BIOS code stopped there. That looks not in recovery procedure. The BIOS is finding strobes edge.
Can you tell me what means that? Thank you so much.
