Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
BLDK Post codes
JOff
I'm trying to bring up new hardware similar to Crown Bay and not getting serial output out of a binary generated from the BLDK.
I do get POST codes however, and the last one is 0xb6. I'm trying to figure out what this code means and where to look next as to what the problem may be why I'm not getting serial output. I have not been able to locate the reference of POST codes for BLDK or find the source that is responsible for sending it.
I have instrumented an FPGA to further capture the POST codes before the 0xb6 and there are 10 of them.
a0
a1
a2
a3
a4
a8
d2 (written twice)
a9
b6
FMcNu1
Valued Contributor I
Here is a response from Intel's BLDK expert:
All post code are only used in MRC code as follows:
/* Checkpoint progress indicators written to port 80h */
# define STS_CHIPSET_INIT 0xA0 // Initialize processor and version number saved
# define STS_RESET_STATE 0xA1 // Detect host reset state
# define STS_FREQ_DETECT 0xA2 // Detect DDR frequency
# define STS_PARAM_CONFG 0xA3 // Detect DDR parameters
# define STS_VERIFY_CONFIG 0xA4 // Verify DDR parameters programmed
# define STS_JEDEC_INIT 0xA8 // Perform the appropriate JEDEC initialization
# define STS_CPU_CONFIG 0xA9 // Clear FIFO command sent to P-Unit
# define STS_MRC_DONE 0xB6 // End of memory initialization
From the information you provided, "0xB6" means the system probably passed the MRC initialization successfully.
I hope this helps
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
JOff
Thank you for that. I grepped for those # define's in my BLDK source and was not able to find them so I assume they are in some non-open part of the BLDK code base?
We'd really like to get this board doing something other than sending POST codes soon. Preferably outputing the UEFI shell over the serial console (this board is headless). We're willing to pay for some help from a contractor if thats what it takes. As it is right now, we have no idea where to even start looking for potential problems with our prototype with only undocumented POST codes to go by.
Is the 0xD2 POST code we get before the 0xB6 any clue? What is the next POST code that would be sent after 0xB6 (our last one before lockup) since it seems the POST codes on the BLDK are not an indication of errors but indications of boot status.
My email address: mailto:[email protected] [email protected]
MMori9
The code 0xB6 is the last code that is outputted by the default bootloader, but it is far from finished at that moment (only the memory initialization has finished). What you can do is download the BLDK source package (CB-EDKII-PostGold-2.3.6.8) and add postcodes yourself to see the progress of the bootloader.
JAran1
My apologies for coming back to this old thread but I could not find any help elsewhere (even from Intel Support).
I am FAE and a customer of mine is running a very seemed problem now.
The difference is that they are NOT using BLDK, but Coreboot (that is using FSP, by its turn).
Sequence codes are the same:
- A2, A3, A4, A8, D2, A9, B6
Generated Coreboot firmware hangs after "B6".
Intel FSP for Queens Bay running on Atom processor E620 hangs and I cannot find any documentation on the meaning of the displayed status codes.
Where is can I find the meaning of this codes for sure?
Since FSP only gives me a binary to link against my firmware (Coreboot), does anyone have any clues on how to check if things are running fine in the FSP part?
Really thanks.
Casey_H_Intel
Hello Jaques,
The B6 code means that the MRC has completed successfully.
The Intel® Firmware Support Package is http://www.intel.com/fsp available here. Look for "Intel® Atom™ processor E6xx series with Intel® Platform Controller Hub EG20T (formerly Queens Bay: Tunnel Creek and Topcliff)"
If your customer has an issue, you may want to submit an issue for them via IPS.
Casey H.
JAran1
Thanks for replying Chaas.
I have already downloaded and installed FSP for Queens Bay, as I should have told before.
Unfortunately there is no mention to "B6" or any of this codes anywhere!
Where did you find such information?
Casey_H_Intel
The B6 code is referenced on page 35 in the https://www-ssl.intel.com/content/www/us/en/intelligent-systems/intel-boot-loader-development-kit/bldk-atom-pxe-boot-paper.html "Implementing Network Booting Using Intel® BLDK" white paper".
"The 7-Segment LED display should read b6. If it reads 00 or any other value then the image is probably corrupt and malfunctioning."
Casey H.
