Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Can't flash Gordon Peak MRB board
Zide_C_Intel
After "r" "n" "4", the IOC console shows the following, but flashing is not started. Any suggestions are appreciated!
00:00 00s362ms master_state_engine -> wait for all modules
00:00 00s362ms cbc_logic_core -> startup(2 - late)
00:00 00s363ms cbc_logic_core -> on state
00:00 00s367ms console_queue -> startup(1)
00:00 00s367ms timestamp -> startup(1)
00:00 00s372ms console_queue -> on state
00:00 00s372ms timestamp -> on state
00:00 00s603ms abl_control_uart -> on state
00:00 00s603ms Startup Counter: 1
00:00 00s603ms System Start completed! (ABL Blob 1)
00:00 00s603ms master_state_engine -> on state
00:00 00s603ms ------------------------------------------------------
00:00 00s603ms ACTIVE stay alive Reasons:
00:00 00s603ms wakeup button (trigger)
00:00 00s603ms UART reset performed
00:00 00s755ms UART reset performed
00:00 02s890ms Terminal command: n Do start system (1 = Normal, 2 = Recovery, 3 = Download, 4 = Emergency, 0 = Shell): Input: 4
00:00 02s890ms Wakeup button state (emergency boot)
00:00 02s890ms DNX disabled
00:00 02s890ms Set boot selector for(once) to ID 0x4
00:00 02s890ms Boot Selector: using once entry
00:00 09s852ms Changed HW flow control setting for UART 5 to 1
00:02 10s187ms Temp. (id 0) = 33 C; Temp. (id 1) = 31 C; Supply: 12.27 V atc = 2; FAN 99 rpm; FAN 15 %
CarlosAM_INTEL
Hello, Z.Chen:
In order to help you, we will contact you via email.
Carlos_A.
