Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Cant add custom resolution?
zdegore
I have a PLC system using Windows 10 IoT enterprise 2021, and intel HD graphics 500. I need to set the resolution to 800x480, however this is not an option, I've tried a variety of things CRU, editing reg values,  Set-DisplayResolution powershell module, but nothing works.
I have an older but very similar system which is instead using intel hd graphics and I was able to delete that driver and revert to the basic display adapter and set a custom resolution through reg values. However when I delete the driver for HD 500 system, it reverts to basic display adapter but it greys out resolution setting all together and I cannot set the resolution.
It also seems to be using a different driver file "...DriverStore\basicdisplay.inf_amd64_....\BasicDisplay.sys" as opposed to the older systems "...System32\drivers\BasicDisplay.sys"
Im not sure if there is a different way to set the resolution or if there is a way to switch the drivers on the current system?
Labels (2)
Mike_Intel
Hello zdegore,
  1. What is the model of your processor?
  2. Are you using a desktop or a laptop?
  3. What is the complete brand and model of your system?
  4. What are the troubleshooting steps that you tried so far?
Michael L.
zdegore
Processor is Atom x5-e3940, I am using an industrial pc from Beckhoff (c6015-0020). I have tried using CRU, setting registry values, and set-displayresolution power shell command. Since the system is using intel HD graphics 500 I tried removing this display driver and reverting to basic display adapter which worked on a different device but not in this case, when I did on this device it greys out the resolution drop down all together.
Mike_Intel
Hello zdegore,
Thank you for the update.
Just to check, have you tried checking this issue with Beckhoff?
OEM manufacturers can alter, modify or enhance a controller and since this is an OEM system. They may have a custom settings in place.
Michael L.
zdegore
I have not, I can check with them now and let you know what they say.
Mike_Intel
Hello zdegore,
I hope you are now talking to them regarding this issue since this system is a custom system from them.
Michael L.
zdegore
Yes, they did let me know that this resolution is not supported.
Mike_Intel
Hello zdegore,
They already answered your inquiry since this is a custom system made by an OEM manufacturer.
If you still have questions or clarifications, please let us know. Thank you.
Michael L.
