Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Desperate for an audio driver
KMurr
I recently purchased a Dell Ispiron 620 with a Core i3 2120 processor. It came with Windows 7 installed, but I had to install Windows XP because certain programs I need to run will not run on W7. I can't find any audio drivers that will work with Windows XP. Any help or advice will be greatly appreciated!
Thanks in advance
FMcNu1
Valued Contributor I
Hello and welcome to the Intel® Embedded Community.
Our community is focused on embedded applications and the issue you describe pertains to a consumer PC. So you are really not in the right place to solve your problem. Your best avenue for support for your Dell PC, including drivers, is to contact Dell directly. http://support.dell.com/ http://support.dell.com I personally have a Dell PC and have found good success with Dell support.
I hope this helps
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
