Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Ether Net Controller I210
ken_ken_3
I was checking the peripheral circuit of the Ether Net Controller I210,
The recommended transformer described in the datasheet is
Bell S588-5999-P3
I checked the data sheet on Bell's HP, but I couldn't find it. The one I found on HP was S558-5999-P3.
Is the description in the I210 datasheet correct?
Below is the data sheet for your reference.
・Intel Ethernet Controller I210 Datasheet Networking Division (ND)
Applicable item 12.5.3 Third-Party Magnetics Manufacturers Page 814
Diego_INTEL
Hello @ken_ken_3 ,
You are welcome.
@Diego_INTEL
Diego_INTEL
Hello @ken_ken_3,
Yes, I have verified and you are right. There isn't a part number from Bel S588-5999-P3, the correct one is S558-5999-P3. It seems that is a typographical error.
In these cases you can check other parts to have an idea what are the characteristics of the component that must be used, you don't have to implement the exact part because sometimes they won't be available, but they can give us an idea of what can be used. In this case, the component must have an impedance of 350µH and to be used for LAN in the type of the transformer.
Thank you for sharing your find.
@Diego_INTEL
ken_ken_3
Hi @Diego_INTEL,
Thank you for your message.
We will continue to consider this device.
Diego_INTEL
Hello @ken_ken_3 ,
You are welcome.
@Diego_INTEL
