Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Host Write Access to ME/EC  setting
nilesh
Hi;
Our product is using the "Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz" process and our Bios vendor is American Megatrend.
Our Access setting to Management engine and Embedded controller are as below, as per Intel MEInfo tool output.
Host Write Access to ME                     Disabled
Host Read Access to EC                       Disabled
Host Write Access to EC                      Disabled
With above setting, is it possible to update the Management engine and Embedded controller firmware.  If yes please inform about what process/tool need to use to update firmware.
Or above Acsess setting will not allow to update EC/ME firmware?
Thanks and Regards,
Nilesh
CarlosAM_INTEL
Hello, @nilesh:
You should review with the assistance of your Intel BIOS vendor (IBV) that your implementation fulfills the requirements stated in section 6.3.12.6, on pages 189, 190, and 191 of the Intel® Management Engine (Intel® ME) 11.X BIOS Specification document # 549522. You can find it when you are logged into your Resource & Design Center (RDC) privileged account on the following websites:
https://cdrdv2.intel.com/v1/dl/getContent/549522
You should fill out the RDC Account Support form to process your account update request or report any inconveniences with the provided site. You can be found on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
