Hello, trying to use my ITP-XDP3 device to debug any developers board. ITP-XDP3 device not working, it can't connect to target device. I trying to use Intel System Studio 2020 Up-3. USB driver work correctly, Windows device manager see ITP-XDP, Intel system debugger device
When i start DAL diagnostic test, i get next log:
>>>Launching hardware recognition...
24.09.2024 18:08:31 Server.HI: PodPlugged [51542046]
Devices Found:
*) serial # --- Link Type
a) 51542046 --- USB
Choose ITP-Hardware from the above list: <string>:1: DeprecationWarning: object.__new__() takes no parameters
* HARDWARE CONFIGURATION DETECTED
Connection Detected
Pod Type = XDP3B
Pod ID = 51542046
Link Type = USB
FPGA version(Pod)= None
FPGA version(Xml)= 09020215
Driver version = 02000300
Assembly version = 00
>>>Launching MEM CONFIG test...
BASEBOARD:
*** FAILURE *** Sending Vendor Request.
ERROR occured during script!
>>>Launching Customer Diagnostics loopback test...
XDP3 Customer Diagnostics Software Version 1.0
24.09.2024 18:11:10
XDP3 FPGA Image Revision: None
XDP3 Board Type is XDP3B
TEST: test_CUST_SETUP_XDP3 2024-09-24 18:13:31-HostWrapper CRITICAL: Exception XDP3B[312781e].WriteMemory( 0,5,0,False,None,None)
Xdpa Write DMA request failed
2024-09-24 18:13:41-HostWrapper CRITICAL: Exception XDP3B[312781e].WriteMemory( 256,43,0,True,None,None)
2024-09-24 18:14:26-HostWrapper CRITICAL: XDP3B[312781e]HostInterface.cancelRead(chn=0) Timeout45(s)
2024-09-24 18:14:36-HostWrapper CRITICAL: XDP3B[312781e].ResetAll-[fff9fff9]
2024-09-24 18:14:46-HostWrapper CRITICAL: XDP3B[312781e].Reset-USB[40004]
TEST: test_CUST_SETUP_XDP3 FAILED!
I tested ITP-XDP debugger with two targets with Core i5 processors and it can't see both targets.
Is my ITP-XDP device is broken? Maybe i need to update FPGA firmware on device? I bought it in used condition to education embedded devices.
Hello, @Sergio_Triales:
Thank you for contacting Intel Embedded Support.
We have received your request but we need to address the following questions to understand it:
Could you please clarify if this request is related to a design developed by you or by a third-party company?
Could you please let us know the name of the manufacturer, the part number, and where we can find the information if this request is related to a third-party design?
If it is your design, please let us know the place of purchase of the cited Intel processors and their part numbers.
How do you obtain the Intel® In-Target Probe (Intel® ITP) eXtended Debug Port (XDP)?
Based on the email address related to your account, could you please confirm if your phone number is: +7 843 227 40 80?
We are waiting for your reply.
Hello @Sergio_Triales,
I was checking this forum, besides my co-worker mentioned, I think you may try looking for any available guide first.
You can try looking for public information like the following:
You can check the "Get started..." documents:
Here is a video:
I hope this may be of help.
hello
I am currently debugging a development board equipped with the A3960 CPU. However, I don't have the same software as you do. But I do have hardware tools. Could you please send me your software so that I can complete the debugging work?
My email is <ww2742628020@outlook.com>
Thank you.
Hello @xmao,
Apollo Lake is not supported anymore but you still can try to access the available documentation for this platform.
https://www.intel.com/content/www/us/en/products/platforms/details/apollo-lake/docs.html
