Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
Intel RST Service not running. How to resolve for Windows 10
NAcun
Intel Rapid Storage Technology was running on my computer successfully in Windows 10 Technical Preview Build 9926. On all subsequent builds, the check for which version of .Net framework, looking for 4.5 is failing in the logs. As there are millions using Windows 10 Technical Preview, am looking for a resolution starting with build 10041 or 10049. I am currently running build 10051 but suspect the resolution is the same. Any advice? Thanks in advance.
Josue_C_Intel
Hello Norman Acunis,
Welcome to Intel® Embedded Community.
As you mentioned above Windows 10 OS is very recent and still under review, Intel® has not validated this OS. We recommend you to use another OS meanwhile.
Regards.
Josue.
NAcun
Microsoft resolved this in May by making available in the Beta Store a fake .net framework 4.0 which when installed then tricks code that looks for it not to fail
Thanks for sharing your findings with the Embedded Community, Norm!
