Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
Intelligent Process Control in Power & Energy Delivers Better Power Efficiency
LFale1
Market: Power & Energy
Technology Partner: AutomationX
Project Introduction
As many energy companies seek to reduce their footprint on the environment, more efficient
power and energy generation is becoming a critical issue. In the power generation and distribution
market, maintenance-free power backup systems and IEC 61850-based power transmission
and distribution systems improve energy generation and distribution efficiency. Power substations
are subsidiaries of electricity generation systems where voltage is transformed from high to low
or reversed using transformers. Nowadays, multiple protocols, including many proprietary protocols
with custom communication links, exist for substation automation and interoperation
with devices from different vendors that would be a huge advantage to users of substation
automation devices.
System Requirements
The IEC 61850 international standard for substation automation systems defines the communication
protocols between devices in substations and related systems and as such any equipment
needs to be compliant with this standard. In next-generation IEC-61850 certified power substation
systems, communication gateways and managed switches play an important role. Abstract data
models, defined in IEC 61850, can be mapped to a number of protocols, and there are many
proprietary devices and networks which are defined in such a way as to link all proprietary devices
together.
System Description
AutomationX is an Austrian-based automation solution provider in the industry, infrastructure
and energy fields. They recently designed Power and Energy Modules for a substation customer
using their PLC programming tool and Advantech's acclaimed APAX-5000 series Programmable
Automation Controllers (PLC), as well as UNO series.
Advantech was chosen by AutomationX for their wide product portfolio, and because the harsh
working environments in power substations require that equipment has to meet robust design
specifications, such as wide operating temperature range, isolation I/O, dual power input, vibration
and shock protection, and rackmount installation.
The APAX-5000 series integrates control, information processing and networking in a single platform.
By leveraging the latest automation technology, AutomationX and the APAX-5000 series
PAC system provide a more reliable, scalable and flexible substation control and automation
application.
