Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
PXA27x Processor failed by temperature
KFrie2
Hello together,
we still using the pxa27x processor at 624 MHz in our plattform. We use the RTPXA270C5C624 (stepping C5).
Our firmware failes when the surrounding temperature rises.
The case temperature of the pxa27x processor is 71°C. When we are cooling down the processor with help of a peltier element, the plattfrom doesn't fail.
We apply a VCC_Core Voltage of 1,56V in the regular plattform, which is inside the spec.
When i'm increasing the vcc_core voltage to 1,62V, the plattform doesn't fail too, also when no peltier element is build in as a cooling device.
So i read in the Intel PXA27x Processor Developer's Kit, that there was a issue with the vcc_core voltage in the RTPXA270C0C624 processor with the stepping C0.
Is there still an issue with the vcc_core voltage in the RTPXA270C5624 processor with the stepping C5?
Kind regards
Konstantin
CarlosAM_INTEL
Hello, SpaceMachine :
The cited device is part of the Intel(R) XScale family that is manufactured by other company as is stated as a reference at the following websites:
https://www.intel.com/pressroom/archive/releases/2006/20060627corp.htm https://www.intel.com/pressroom/archive/releases/2006/20060627corp.htm
http://www.marvell.com/company/news/pressDetail.do?releaseID=976 http://www.marvell.com/company/news/pressDetail.do?releaseID=976
Due to this fact, we suggest to address your consultations for the cited products as a reference at the channels listed at:
http://www.marvell.com/support/contact/cust_support.do http://www.marvell.com/support/contact/cust_support.do
http://www.marvell.com/support/ http://www.marvell.com/support/
We hope that this information may help you.
Carlos_A.
