Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
Platform Designer layout for a Mandelbrot viewer
Fred_Barkins
Couldn't find the right field under "Select Location" so had to go with the closest thing...
I’ve been trying to implement on my DE1-SoC an outstanding Mandelbrot Viewer written by 3 fellows at Cornell, which published partial information in an online available final report.
I manage to compile the C++ code and perform a sanity check on my x86 host:​
And I manage to compile the C++ to run on the DE1-SoC HPS:
Also, I got Quartus to compile the Verilog provided in the report, though it’s not in its final, working form.
I’m pretty sure my problem is in the Platform Designer (formerly Qsys) layout.
Been trying many variations around this layout for several weeks, but with no success:​
I chose the components to my best understanding based the report, that mentions:
  1. The communication between the FPGA and the hard processor system happens over a memory-mapped AXI bus. Requests for tiles are placed into a FIFO on the FPGA, and solved tile data is written out into external SDRAM memory.
  1. Requests from the HPS are sent over the AXI bus into a FIFO located on the FPGA. A request distributor then pulls the message off of the FIFO using the avalon streaming interface and handles it.
* I assume this is with reference to request_distributor.sv
  1. As the solvers solve pixels of the output tile, they write the results to SDRAM. Arbitration logic collects results from any solvers which are ready to write.
* I assume this is with reference to write_arbitrator.sv
Additional info: To my understanding, a top module (not attached to the report) is probably instantiating a multi_tile_solver.sv module and a module from Platform Designer, nothing more. As can be seen in the files in the report, multi_tile_solver.sv instantiates a request_distributor.sv module, a write_arbitrator.sv module, and NUM_SOLVERS tile_solver_legit.sv modules. Each tile_solver_legit.sv instantiates a solver.v, which instantiates a solver_control.v and a solver_datapath.v. It uses on-chip SRAM in the form of M10K block, which are created from the verilog source code, rather than having anything to do with the Platform Designer layout.
I think I’m pretty close to running this amazing project, yet have been stuck on this platform designer layout and don’t succeed in finalizing. Any help would be much appreciated.
Diego_INTEL
Hello @Fred_Barkins,
You can try in the Altera Community, please check the following message:
FPGA community forums and blogs have moved to the Altera Community. Existing Intel Community members can sign in with their current credentials.
@Diego_INTEL
