Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Ram selection
HChri2
the stated RAM speed for i76700 cpu is 2133 can a faster speed be used without problems
CarlosAM_INTEL
Hello NewBee2016,
Thank you for contacting the Intel Embedded Community.
In order to better understanding your consultation, could you please tell us if it is related to a motherboard? Please give us all the information of this motherboard.
By the way, please refer to the forums https://communities.intel.com/thread/88430 Does XMP work with i7-6700? and https://communities.intel.com/thread/97226 Questions about memory controllers / maximum ba... as a reference that may help you.
Thanks for your collaboration to answer your question.
Carlos_A
HChri2
Thank You for Responding!
I plan on building a desktop with a Intel (6700 i7 core) or (6700K i7 core) and an Asus Z-170-A mobo.
From the post you gave me it sounds like it causes problems if you buy RAM faster than the spec of the CPU of 2133.
This is a dual channel mobo would it be better to populate the mobo with two sticks of RAM 16Gb in one channel or four sticks of RAM 8Gb in two channels, as far as to help the CPU run better?
If i go with the 6700K it will come out of the box and run @ 4 GHz and turbo to 4.2 GHz with no bios or set up, and this would not be over clocked. But if i go with just the 6700 it runs @ 3.4 GHz and turbo to 4.0 GHz, is that correct ?
CarlosAM_INTEL
Hello NewBee2016,
Thanks for your reply.
We would like to help you, but you need to contact the manufacturer of your motherboard to receive the further help because they have all the information related to their products.
In order to help you, as a reference please address your problem to the following web sites:
https://www.asus.com/us/Motherboards/Z170-A/ Z170-A | Motherboards | ASUS USA
http://www.asus.com/us/support/ Support Center | ASUS USA
https://vip.asus.com/VIP2/Services/QuestionForm/TechQuery?lang=en-us ASUS Email Us
We hope that this information is useful to you.
Carlos_A.
HChri2
Thank you Carlos,
Can you answer the part of my questions that deals with the Intel Chips or give me a link for the Intel part of questions?
Thank You
Howard
CarlosAM_INTEL
Hello NewBee2016,
Since you are using a Desktop instead of an Embedded processor, we suggest you to address your questions to the https://communities.intel.com/community/tech/processors Forum: Processors | Intel Communities.
Carlos_A.
