Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
Starting Weston
FCama1
I'm having an issue when I try to start "weston":
root@gr-mrb-64:/home/root# /usr/bin/weston &
[1] 2192
root@gr-mrb-64:/home/root# Date: 2018-02-05 UTC
[17:53:42.174] weston 1.10.0
http://wayland.freedesktop.org
Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=1.10.0
Build: 1.1.0-2720-g18b41f3-dirty (18b41f36cd682a624ab68f83d6f9c3a1a930d093)
[17:53:42.174] OS: Linux, 4.1.27-yocto-standard-fc, # 1 SMP PREEMPT Tue Feb 6 22:24:22 CET 2018, x86_64
[17:53:42.174] Using config file '/home/ias_graphics//.config/weston.ini'
[17:53:42.174] Output repaint window is 7 ms maximum.
[17:53:42.174] Loading module '/usr/lib/weston/ias-backend.so'
[17:53:42.180] initializing Intel Automotive Solutions backend
[17:53:42.180] logind: failed to get session seat
[17:53:42.180] logind: cannot setup systemd-logind helper (-61), using legacy fallback
[17:53:42.182] using /dev/dri/card0
[17:53:42.182] Loading module '/usr/lib/weston/gl-renderer.so'
[17:53:42.192] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_EXT_platform_wayland
EGL_MESA_platform_gbm EGL_KHR_client_get_all_proc_addresses
EGL_KHR_debug
[17:53:42.193] warning: EGL_EXT_swap_buffers_with_damage not supported. Performance could be affected.
[17:53:42.196] Found 1 matching sets of display components to build
[17:53:42.196] Using the classic output model.
[17:53:42.196] drm object 25 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.197] drm object 28 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.197] drm object 31 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.197] drm object 32 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.197] drm object 33 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.197] drm object 34 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.197] drm object 36 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.198] drm object 37 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.198] drm object 38 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.198] drm object 39 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.198] drm object 41 (type 0xeeeeeeee) properties: type (5), FB_ID (14), CRTC_ID (15), CRTC_X (10), CRTC_Y (11), CRTC_
[17:53:42.198] IAS ERROR: Failed to get mode for CRTC HDMI1; disabling
[17:53:42.198] IAS ERROR: Could not build any suitable CRTC's
[17:53:42.198] failed to create crtcs for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[17:53:42.199] fatal: failed to create compositor backend
[1]+ Done(1) /usr/bin/weston
Francesco
CarlosAM_INTEL
Hello, fcamarda:
In order to help you, we suggest you address the Weston consultations as a reference to the channels listed at:
https://lists.freedesktop.org/mailman/listinfo/wayland-devel https://lists.freedesktop.org/mailman/listinfo/wayland-devel
Also, feel free to use as a reference as well the following website:
https://bugs.freedesktop.org/ https://bugs.freedesktop.org/
Please follow the steps to obtain access stated as a reference at:
https://bugs.freedesktop.org/createaccount.cgi https://bugs.freedesktop.org/createaccount.cgi
We hope that this information may help you.
Carlos_A.
FCama1
Thanks, just notice that weston was already running, Is it possible to change the default fastboot (early video) target to an ivi target as the Android default?
Francesco
CarlosAM_INTEL
Hello, fcamarda:
Thanks for your reply.
The information that may help you is stated at the following websites:
https://github.com/android-ia/manifest/wiki Home · android-ia/manifest Wiki · GitHub
https://01.org/android-ia/user-guides/android-reference-implementations-user-guide https://01.org/android-ia/user-guides/android-reference-implementations-user-guide
https://01.org/android-ia/guides/developers https://01.org/android-ia/guides/developers
We suggest you address your consultations of this type through the channels listed at the https://01.org/community Community | 01.org website.
We hope that this information is useful to you.
Carlos_A.
FCama1
Hello Carlos,
sorry I was not clear, i would like to change the linux BSP EC31 fast boot startup (early video with intel screen shot) to an IVI or some more simple weston-terminal environment with a working keybord?
Is there a way when you start the weston.service to load a different graphic environment? Do I have to add some specific receipt at build time?
Thanks & Regards,
Francesco
CarlosAM_INTEL
Hello, fcamarda:
Thanks for your update.
In order to be on the same page, could you please tell; me where I can find the "linux BSP EC31"?
Waiting for your reply.
Carlos_A.
FCama1
Hi Carlos,
I got the "gp_bsp_ww23.5_ec31_pf_rc1" from the kit search (platformsw.intel.com/KitSearch.aspx kit n 122715)
Francesco
CarlosAM_INTEL
Hello, fcamarda:
Based on your previous message, could you please confirm if it is a Yocto BSP?
Carlos_A.
CarlosAM_INTEL
Hello, fcamarda:
In case that it is related to Yocto Project, your consultations should be addressed as a reference to the channels listed at the following website:
https://www.yoctoproject.org/tools-resources/community/mailing-lists https://www.yoctoproject.org/tools-resources/community/mailing-lists
This suggestion is based on the information stated on page 4 of the https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/atom-processor-e3900-series-product-brief.pdf Product Brief: Intel® Atom™ Processor E3900 series, Intel® Celeron® Processor N3350, and Intel® Pentium® Processor N4200 document # 334896,
Carlos_A.
