Studied from 630711, I don't know:
When should IPL2 or IRMS be used for VCCCORE VR TDC?
Should I config the "VR TDC Time Window" in BIOS Mailbox?
help,thanks.
Hello @kingson6135,
I have found the following internally: The default IA TDC current in BIOS will follow the same as IPL2.
For further support regarding this topic, you can use the Intel Premier support.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
