Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1417 Discussions
Wide-Temp Rugged Embedded Boards Perform 24/7 in Extreme Environments
EChen56
DFI has launched new industrial motherboards powered by the latest Intel® Atom™ processor E3900 family (code name Apollo Lake). For the new series boards, DFI has created a wide array of rugged and reliable products including Mini-ITX, SBC, Pico-ITX, COM Express, Qseven R2.1, and SMARC R2.0. These boards deliver higher computing capabilities and stunning graphics performance at economically low-power consumption that average at only 9 watts TDP. Moreover, they support the extended temperature range from -40°C up to +85°C, which provide appropriate industrial hardware in embedded applications such as transportation, automation, energy, military or aerospace.ComparisonKey Features
Equipped with industrial-grade components, these boards support a wide temperature range of -40 to 85°C durable for any industrial and harsh environments.
The new series powered by enhanced graphic engine supports 4K high resolution (DP: 4096x2304 @ 60Hz) and three independent displays for multimedia solution.
<span style="background-co...
