Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1418 Discussions
compiling with c++11 using make command
well
Dear intel team,
When trying to compile the host code using 'make' command in MobaXterm terminal.
I got this error:
In file included from /usr/include/c++/4.8.2/array:35:0,
                     from host/src/host.cpp:16:
    /usr/include/c++/4.8.2/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
     #error This file requires compiler and library support for the \
I need to know why this error appears, and how to fix it ??
CarlosAM_INTEL
Hello, @well:
You should address as a reference the questions related to the cited third-party tool by filling out the form stated on the following website:
 https://mobaxterm.mobatek.net/contact.html
@CarlosAM_INTEL.
well
Thank you very much. The issue is solved by adding -std=c++11 to the Makefile
CarlosAM_INTEL
Hello, @well:
Thanks for share your solution to this situation.
Please do not hesitate to contact us again with all the information about the Intel Embedded devices related to your future questions.
@CarlosAM_INTEL.
