Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
eeupdateARMTool
KVara1
Hi Intel Team,
Could you please provide us eeupdate ARM tool to flash i210 available in our ARM64 SoC
Please send to mailto:[email protected] [email protected]
YShin10
Dear Intel,
The eeupdate ARM tool is not working on my target device.
> ./eeupdate.dat -nic=1 -f=/data/I210_Invm_SerDesBX_NoAPM_v0.6.HEX -mac=020400000100
Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool Version 0.7.5
Provided under the terms of a CNDA. Do Not Distribute.
Copyright(C) 2017-2018 by Intel(R) Corporation
Device Location temp ************** = /proc/bus/pci/0000:01/00.0Device Location temp # = /proc/bus/pci/0000:01/00.0Config = ?€1 Config 4 and Config 5
Config 6
Updating command word..... Done!
Run as a root user !! Error at line 688 in file ./PciEeprom.c (errno: 2, description: No such file or directory)
Device is not mapped.
Could you check this tool again ?
If you can provide the source code of this tool, I will try to cross-compile it.
Please contact me via mailto:[email protected] [email protected]
[Project Info.]
*Target device : Arm64 android 8.1 device
*Ethernet device : Springville I210CS
CarlosAM_INTEL
Hello, yongho:
In order to be on the same page, could you please tell us if the affected device is a project developed by you or a third-party design? In case that it is a third-party one, could you please tell us all the details related to it? In case that it is your own design, could you please list us the sources that you have used to develop it and if it has been reviewed by Intel?
Waiting for your answers to these questions.
Carlos_A.
CarlosAM_INTEL
Hello, Kiruthika:
In order to help you, we will contact you via email.
Carlos_A.
KVara1
Hi Intel Team,
The tool which you have provided does not support flashing MAC address.
Could you provide eeupdate or any tool with which we can flash MAC address
Kiruthika
CarlosAM_INTEL
Hello, Kiruthika :
Thanks for your reply.
The https://cdrdv2.intel.com/v1/dl/getContent/348742 Intel(R) Network Connections Tools document # 348742 has the Eeupdate tool.
It is accessible when you are logged into your Resource & Design Center (RDC) privileged account. It can be requested by filling out the https://www.intel.com/content/www/us/en/forms/design/contact-support.html RDC Account Support form.
We hope that this information may help you.
Carlos_A.
