Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
1416 Discussions
error message "D3DM Wrapper Driver: ERROR: Vertex Processing needs clipping"
MBloe
We are porting a Windows CE application from DirectX to Direct3DMobile, so far it works fine but performance is an issue. We noticed that the driver outputs the following error:
D3DM Wrapper Driver: ERROR: Vertex Processing needs clipping!
We were able to reproduce this problem with (a slight modification to) the D3DMobile tutorial application 5 (textures).
In the function InitGeometry, multiplied the X and Z position of both vectors by 3
example: pVertices[2*i+0].position = VECTOR3( (float)sin(theta) * 3,-1.0f, (float)cos(theta) * 3 );
The cilinder then touches the sides of the window and the driver outputs the message.
What are we doing wrong?
We have Windows CE 5 and 6, using the IEGD 10.3.1 driver on a 945GME chipset.
Thanks in advance,
Maikel Bloemendal
Embedded software engineer
