Embedded Intel® Core™ Processors
Communicate Intel® Core™ Hardware, Software, Firmware, Graphics Concerns
qat_mem non root access
BDeni
I building QAT1.6 driver and openssl-async. All working fine, but as root.
I have tried:
chmod g=rw /dev/icp_*
chgrp ${GROUP} /dev/icp_*
chmod g=rw /dev/qat_mem
chgrp ${GROUP} /dev/qat_mem
but getting the following error:
mmap: 11 Resource temporarily unavailable: Resource temporarily unavailable
crypto_alloc_from_slab error, create_slab failed - memory allocation error
How do i allow non-root access to qat_mem?
CarlosAM_INTEL
Hello Bobik,
In order to help you in the best way possible, could you please tell us the part numbers of the Intel devices related to this consultation?
Thanks in advance for your collaboration.
Carlos_A.
BDeni
Silicom PE2iSCO3 chipset DH8955CL
driver version: L.2.5.0-80
openssl patch version: 0.4.9-009
CarlosAM_INTEL
Hello Bobik,
Thanks for your update.
We would like to help you, but you need to contact the manufacturer of the mentioned Crypto Compression PCI E G3 Server Adapter to receive the further help because they have all the information related to their products.
In order to help you, as a reference please address your problem by filling the form that you can find at the following web site:
http://www.silicom-usa.com/contactus.aspx?Item=693&Product=270&ln=en Contact Us
Please let us know if this information is useful to you.
Carlos_A.
BDeni
And what is the difference between qat_mem and qae_mem? Which driver is recommended to use? I did not find this in the documentation.
CarlosAM_INTEL
Hello Bobik,
Thanks for your reply.
The qae_mem information that may help you can be found as a reference in section 3.2.7 specifically at the Resolution field, on page 26 of the http://www.intel.com/content/dam/www/public/us/en/documents/release-notes/quickassist-technology-software-release-notes.pdf Intel(R) QuickAssist Technology Software Package Release Notes Version: QATmux.L.1.1.0-60; also in section 5.16 specifically at the step 7, on page 64 of the https://01.org/sites/default/files/page/330753-003_cck_pg.pdf Intel(R) Communications Chipset 8900 to 8920 Series Software Programmer's Guide.
We hope that this information is useful to you.
Carlos_A.
