We are seeking full material disclosure information according to IPC 1752a Class D requirements for the following parts
| RC28F160C3TC110 |
| TE28F320C3TA90 |
| TE28F320C3TC70 |
| TE28F320C3TC90 |
| TE28F320C3TD70 |
| TE28F320C3TD90 |
| GE28F160C3TC70 |
| GE28F160C3TC90 |
| GE28F160C3TD70 |
| RC28F640K3C110 |
| PH28F160C3TD70 S B93 |
| RC28F256P30B85 |
| RC28F256P30B85 S B93 |
| PC28F128P30T85 |
| PC28F640P30B85S B93 |
| PC28F640P30B85S B48 |
| PC28F640P30B85 |
| QE82527 |
| QE82527MM863661 |
Please help to provide the information. Thanks.
Hello, @BrianNovAtel:
The last two part numbers on the received list are Intel(R) Microcontrollers. You should refer to the attached document, also the one stated on the following website:
http://qdms.intel.com/dm/d.aspx/7C715FEC-C598-444E-9EFB-2750B98F7956/PCN106013-01.pdf
The rest of the part numbers are Flash Memories. This product has been transferred to Micron, as you can confirm at the following websites:
https://www.intel.com/pressroom/archive/releases/2008/20080330corp.htm
http://www.intel.com/pressroom/archive/reference/Micron_press_release.pdf
Due to this, you need to contact the cited company to obtain the requested information.
