Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
311 Discussions
How to generate 10G Base KR test patterns in Intel Xeon DE - D1559
KMANO3
we developed custom board based on Intel Xeon D-1559 processor. It has 2 ports of 10G Base KR - SFP+ ports on the board. we are now performing electrical validation of these two ports using pre-compliance scope software. Kindly suggest how do we generate the below test patterns
  1. How to generate 8 ZEROS and 8 ONES Pattern?
  2. How to generate PRBS31 Pattern?
  3. How to put PHY into a Loopback for RX Testing on both ports
  4. How to gain access to 10G PHY TX registers to tune emphasis values in case failures are encountered on TX side?
  5. How to gain access to 10G PHY RX registers to tune EQ values in case failures are encountered during RX testing?
Request your support for the same
CarlosAM_INTEL
Hello, @KMANO3:
Could you please clarify if this forum is related to the following thread?
https://community.intel.com/t5/Embedded-Server/Test-pattern-generator-for-10G/m-p/1205787#M638
We are waiting for your clarification.
@CarlosAM_INTEL.
