Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
310 Discussions
Interface Concept - New 6U VPX dual Intel® Xeon®D-15xx processor-based Digital Signal processing board
GHeli
Interface Concept, a leading developer and manufacturer of high-performance embedded COTS boards and systems unveils the IC-INT-VPX6e, a Server Class Digital Signal Processing (DSP) board, based on two Intel® Xeon® D-15xx processors (12-core version), in a 6U VPX form factor.
The IC-INT-VPX6e combines unmatched performance at low power with the leading-edge Intel® Xeon® 14nm System-on-Chip (SoC) package, together with up to 64GB high-speed DDR4 memory.
This new IC-INT-VPX6e board represents a real enhanced dual Intel processor-based design, ideal for use in systems deployed in compute-intensive and defense applications.
Complying with the OpenVPX™ standard and featuring a PCIe Gen 2/3 switch as well as a GigaEthernet low latency switch, the IC-INT-VPX6e offers 16 lanes on the data and expansion planes, GigaEthernet ports on the control plane and additional 10GigaE interfaces.
In that way, it is easily "pluggable" in custom or standard full mesh backplane or in centralized system when interfaced with our ComEth4510a or ComEth4115a switches.
The board also features scalable and secured SATA Nand SDD, GPIOs, USB, SATA ports as well as two VGA interfaces provided by one Silicon Motion SM750 GPUs.
"Our engineering team has developed a concentrate of performance that will be most welcome by our customers for their high-demanding applications, "said Bruno Rolland, Interface Concept's president.
Interface Concept provides Linux® LSP (IC SDK, others...) and BSP for VxWorks® together with the board.
Compliant with OpenVPX™ standard, it is available in air-cooled and conduction cooled versions (compliant with VITA 47 classes).
