Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
307 Discussions
Slow performance on a 2 Haswell cpu system
Jaspers95
I'm seeing a slow performance on one of the two Haswell CPUs on my system. I'm running two instances of the same test application on a system running Linux with 2 Intel(R) Xeon(R) CPU E5-2628L v3 @ 2.00GHz processors. Each application is pinned to one cpu using taskset:
taskset -c 0-9 testApp -threads 10
taskset -c 10-19 testApp -threads 10
What I'm seeing is that the testApp running on cores 0-9 takes about 10 times longer than the testApp running on cores 10-19
Using perf stat -ddd I saw that some.of rhe cache loads (l1, LLC) were a lot slower for the testApp on cores 0-9 and therefore the resulting instructions per cycle was a lot lower.
Also the slowness only starts to appear with 4 or more threads - at least it's only noticeable with the timing metrics I'm using.
We've also seen that rebooting the node can clear the problem, so it seems to be intermittent. We have three other identical systems and this has been observed on one of the others as well.
Any ideas what could cause this or what I could look at to determine what's happening?
Alberto_Sykes
Jaspers95, Thank you for posting in the Intel® Communities Support.
In reference to this scenario and in order for us to provide the most accurate assistance on this matter, I will move your thread to the proper department so they can further assist you with this topic.
Albert R.
A Contingent Worker at Intel
CarlosAM_INTEL
Hello, @Jaspers95:
We suggest confirming this situation with the Intel® Processor Diagnostic Tool.  You can find it on the following website:
https://downloadcenter.intel.com/download/19792
By the way, we want to address the following consultations to have a better idea of this situation:
Could you please give all the details of the tool, the Linux variant, and its flavor used previously to determine the reported issue?
Could you please clarify if the affected design has been developed by you or by a third-party vendor? Could you please let us know the part number, model, and name of the manufacturer if it is a third-party design?
We are waiting for your answer to these questions.
@CarlosAM_INTEL.
