Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
318 Discussions
The Final Intel USB 3.0 eXtensible Host Controller Driver for C216 chipset
HAiza
Where can we get the Intel USB 3.0 eXtensible Host Controller Driver for C216 chipset?
I understood it is a discontinued product but I would like to get the final release version.
https://www.intel.com/content/www/us/en/support/articles/000031615/software/chipset-software.html
CarlosAM_INTEL
Hello, @HAiza​:
Thanks you for contacting Intel Embedded Community.
We suggest use the Intel(R) Driver & Support Assistant [Intel(R) DSA] to automatically detects driver or software updates. It can be found at:
https://www.intel.com/content/www/us/en/support/detect.html
@Mæcenas_INTEL​.
HAiza
Dear @Mæcenas_INTEL (Intel)​.
Thanks for your advice.
The target systems are in the closed network and the OS is Windows Server 2008 R2.
Intel(R) DSA does not work unfortunately.
I would appreciate your continuous support.
CarlosAM_INTEL
Hello, @HAiza​:
Thanks for your update.
We have contacted you via email to help you.
@Mæcenas_INTEL​.
JMcQ
I'm having the same problem. Is there a solution?
n_scott_pearson
I am attaching the versions that I have in my archive. These are for Win7; I presume you know how to convert.
Hope this helps,
JMcQ
I do not, but I'm sure I will figure it out. I think I just need to run the driver in compatibility mode.
Thank you!
CarlosAM_INTEL
Hello, @JMcQ:
You should also consider the information stated on the following website:
https://www.intel.com/content/www/us/en/support/articles/000005533/software/chipset-software.html
@CarlosAM_INTEL.
