Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
315 Discussions
We seen following error with intel xeon microprocessor GG8067402569400SR2DK in our product. Error message- Generic Cache level-2 Generic error and also Processor context corrupt for Bank 17 and Bank 19
VV0001
mcelog: Family 6 Model 56 CPU: only decoding architectural errors Hardware event. This is not a software error.
CPU 4 BANK 17 TSC 5d6953ae81a
RIP !INEXACT! 10:ffffffff8139831a
MISC 4fc389603402086 ADDR fa002000
TIME 1559870123 Fri Jun 7 03:15:23 2019
MCG status:RIPV MCIP
MCi status:
Uncorrected error
Error enabled
MCi_MISC register valid
MCi_ADDR register valid
MCA: corrected filtering (some unreported errors in same region)
Generic CACHE Level-2 Generic Error
STATUS be200000000c110a MCGSTATUS 5
CPUID Vendor Intel Family 6 Model 86
RIP: intel_idle+0xda/0x160}
SOCKET 0 APIC 1 microcode 7000005
CarlosAM_INTEL
Hello, @VV0001​:
Could you please let us know how many units of the project related to this circumstance have been manufactured? How many are affected? Could you please give the failure rate?
Could you please provide topside markings pictures of the processors associated with this issue?
We are waiting for your answer.
@Mæcenas_INTEL​.
VV0001
Hi Team,
Thanks for your kind response. Please find our answers in line below.
How many are affected? one unit is affected.
Could you please provide topside markings pictures of the processors associated with this issue? We have requested with the concerned team, will provide you this at the earliest.
In addition to our above questions, we have few more queries below.
  1. What does MCE error (kernel panic) mean?
  2. Whether the MCE log decoding mechanism used by us are correct or not??
  3. Whether above MCE log decodes to error: Generic Cache level-2 Generic error and also Processor context corrupt for Bank 17 and Bank 19??
  4. Let us know what is the cause of MCE from the decoded MCE log. Whether is it a Hardware failure (CPU internal itself) or Software failure which handling some function??
  5. What does it mean by Generic CACHE Level-2? Whether Cache memory Internal to the CPU?
Please let us know from the above decoded MCE log whether in future it will affect health of the board as node seems to be working fine now.
CarlosAM_INTEL
Hello, @VV0001​:
Thanks for your reply.
The information that may answer your questions as a reference can be found at:
https://access.redhat.com/solutions/18723
https://bugzilla.redhat.com/show_bug.cgi?id=1085785
In case that you want more details of the description of the reported situation, please address your questions as a reference to the channels listed at the following websites:
https://bugzilla.redhat.com/page.cgi?id=redhat/contact.html
https://www.redhat.com/en/services/consulting?extIdCarryOver=true&sc_cid=701f2000001OH7JAAW#GatedFormContainer
On the other hand, we are waiting for the requested pictures to give you some hardware recommendations.
@Mæcenas_INTEL​.
VV0001
Hi Team,
As requested earlier, please find the attached the top side picture of the processor.
Also the links provided above which doesn't contain any solutions, only match with our error prints.
Please provide us the solution for error reported.
CarlosAM_INTEL
Hello, @VV0001​:
Thanks for your update.
Based on your previous communications, could you please swap one unaffected processor with the affected and let us know the results of this change?
We are waiting for your reply.
@Mæcenas_INTEL​.
