Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
X540 De-emphasis
RDeBa
How do I set the transmitter de-emphasis level to -3.5dB on the X540-BT2?
CarlosAM_INTEL
Hello, rdebacker:
In order to be on the same page, could you please tell us if your question is related to the Intel 10 Gigabit Dual Port X540-BT2 I/O Module Network Adapter or the Intel(R) Ethernet Controller X540?
Waiting for your reply.
Carlos_A.
RDeBa
Carlos,
My question concerns the X540 10Gb Ethernet Controller.
Rene
CarlosAM_INTEL
Hello, rdebacker:
Thank you for your clarification.
We suggest you review the information stated in section 9.3.11.13, on page 869 of the https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-x540-datasheet.pdf Intel(R) Ethernet Controller X540 Datasheet document # 333168.
We hope that this information may help you.
Carlos_A.
RDeBa
Carlos,
This bit is read-only and provides status.
I need a method for setting de-emphasis to -3.5dB.
Rene
CarlosAM_INTEL
Hello, rdebacker:
Thanks for your reply.
In order to better understand your request, could you please let us know the purpose to have this information?
Carlos_A.
RDeBa
Carlos,
I am debugging an issue I am having connecting to the PCIe bus.
Current de-emphasis level is -6dB. 2 of 5 prototypes will not link.
PCIe lanes are very short - 1.5 inches.
I would like to see if -3.5dB would help resolve this issue.
Rene
CarlosAM_INTEL
Hello, rdebacker:
Thanks for your update.
Based on your previous communications, could you please let us know the sources that you have used to develop the design related to this situation? please include names and numbers of the documents associated to this.
We really appreciate your cooperation.
Carlos_A.
RDeBa
Carlos,
I have reviewed the following Intel specs regarding this issue:
Intel Ethernet Controller X540 Datasheet Order # 333168-002 Revision: 3.0 January 2016
Intel Ethernet Controller X540 Frequently Asked Questions September 2013 Revision 2.6
X540/I350-BT2 Reference Design Rev 2.1 11/27/2012
X550-BT2/X540/I350-BT2 Reference Design Rev 1.9 10/10/2015
Rene
CarlosAM_INTEL
Hello, rdebacker:
Please let me paraphrase my previous communication, could you please let us know the documents and their numbers that you have used to design the board that is experiencing this technical problem?
Carlos_A .
RDeBa
Carlos,
Here are the available part number plus a few more satellite documents...
333168 Intel Ethernet Controller X540 Datasheet Order # 333168-002 Revision: 3.0 January 2016
No Number Intel Ethernet Controller X540 Frequently Asked Questions September 2013 Revision 2.6
No Number X540/I350-BT2 Reference Design Rev 2.1 11/27/2012
333900 X550-BT2/X540/I350-BT2 Reference Design Rev 1.9 10/10/2015
466430 Intel Ethernet Controller 10G X540-AT2/BT2 Controller Checklists Revision 2.04 6/5/2013
No number Intel Ethernet Controller I350-A Checklists Revision 2.11 8/29/2011
334566 Intel Ethernet Controller X540: Specification Update Rrevision 3.4 1/3/2018
Rene
CarlosAM_INTEL
Hello, rdebacker:
Thanks for your clarification.
Could you please tell us if the affected design has been reviewed by Intel?
Carlos_A.
RDeBa
Carlos,
This design has not been reviewed by Intel.
Our use Altium for schematic capture and Altium is not supported by Intel's automated review tool.
Rene
CarlosAM_INTEL
Hello, rdebacker:
We suggest you send your design to be reviewed by Intel using the Design Review Service. The procedure to use it is stated on the following website:
https://edc.intel.com/Tools/Design-Review/Default.aspx?language=en https://edc.intel.com/Tools/Design-Review/Default.aspx?language=en
Please send it and let us know if the recommendations provide to you may solve the cited problem.
Waiting for your feedback.
Carlos_A.
RDeBa
Carlos,
We use Altium for schematic capture.
The Intel automated schematic tool does not support Altium.
Rene
CarlosAM_INTEL
Hello, rdebacker:
Thanks for your confirmation.
We suggest you previous use Intel Schematic Review service as a reference apply the suggestion stated at:
https://www.altium.com/documentation/15.1/display/ADES/WorkspaceManager_Cmd-ExportToPDF((ExportToPDF))_AD https://www.altium.com/documentation/15.1/display/ADES/WorkspaceManager_Cmd-ExportToPDF((ExportToPDF))_AD
Carlos_A.
