Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
Xeon D-2146IT
Asher1
I can't find any information about Xeon D-2146IT on the website. What is the difference between Xeon D-2146IT and Xeon D-2146NT? Can it be used on the motherboard that supports Xeon D-2146NT?
Diego_INTEL
Hello @Asher1,
I looked internally and found that the D-2164IT is basically the same as the D-2163IT except it supports a faster memory speed, it is recommended to use the same documentation as the D-2163IT.
Regarding the chipset, you are correct, the D-2164IT may use the same chipset as the D-2163IT and in Ark the same chipset is mentioned for the D-2146NT, that is one of the C400 series
https://www.intel.com/content/www/us/en/products/sku/126691/intel-c422-chipset/specifications.html
I hope this may be of help.
@Diego_INTEL
