Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
Xeon D boot problem
khanhcq
Hi!
I'm trying to bring-up a new PCB that using Xeon D-1559 as #561394, #544042 document.
However for some reason PROCPWRGD_PCH and PLTRST_N never go inactive.
I checked some strap pin and critical output from CPU but there is no problem except CATERR_N is asserted after the rising edge of PCB_PWROK ~7ms. And SPI bus does not work, it means SPI_CS0_N is not asserted and there is no clock on SPI_CLK pin and no data on SPI_MOSI pin.
Can anyone advise how to root cause the reason why PROCPWRGD_PCH is not deasserted by the SOC? e.g. which signals to check?
The part-number that I'm using is GG8067402570801S R2M5 and it is my CRB, I refer as TQQ CRB (#556656), it is used for embedded server that Viettel Group is enduser.
My email is [email protected]. I created some IPS about this problem but have not received how to resolve yet. Please help me.
Thank you so much.
CarlosAM_INTEL
Hello, @khanhcq​:
We have contacted to give you a suggestion that may help you in the best way possible.
@Mæcenas_INTEL​.
