Ethernet Products
4891 Discussions
82567LM Gigabit Network Connection Link has been disconnected
I have this error constantly comming up in the event log
Warning 9/30/2009 3:22:09 PM e1yexpress 27 None
Intel(R) 82567LM Gigabit Network Connection Link has been disconnected.
I have a wired connection and I can still surf the Internet, but sometimes the connection slows.
any idea how to fix this?
mcbsys
Same issue with the Dell Optiplex 960 is discussed here:
http://communities.intel.com/thread/9913
Mark Berry
MCB Systems
I've got the same problem on HP DC7900's using the 82567LM-3 NIC. Drop-outs, DNS resolution failing, Netlogon failing and unable to browse DFS. The only thing which offers some help is to set the NIC to use a Static IP Address.
Really need this one fixed....
Update
- set the NIC speed to 10MB/Full - No problem with DNS/DFS/Netlogon but the network is really slow.
- set the NIC speed to 100MB/Full - Problem still exists
- set the NIC speed to 100MB/Full & Port on Cisco switch - no problem with DNS/DFS/Netlogon, but the network is again slower than 100MB.
Is this a case of a dud NIC or dud driver?
I've never had problems with Intel kit before...
is there a solution for XP?
Thanks!
