Ethernet Products
5691 Discussions
82599ES virtual-function unicast promisc mode
cgraf2
Dear all,
I am running a VNF using SR-IOV with the 82599ES NIC.
The VNF needs to receive traffic, which is unequal to the adapters MAC.
As of now, the VNF is not receiving a single unicast-packet due to the mac-mismatch.
So to me I do need promisc-mode for given virtual-function.
My tries to get the same configured are failing, so kindly asking for help.
root@ubuntu-cg:~# dev=ens4f0
root@ubuntu-cg:~# vf=0
root@ubuntu-cg:~# ethtool -i $dev
driver: ixgbe
version: 5.6.3
firmware-version: 0x681b0001, 1.853.0
expansion-rom-version:
bus-info: 0000:81:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
root@ubuntu-cg:~# ethtool -k $dev
Features for ens4f0:
rx-checksumming: on
tx-checksumming: on
    tx-checksum-ipv4: on
    tx-checksum-ip-generic: off [fixed]
    tx-checksum-ipv6: on
    tx-checksum-fcoe-crc: on [fixed]
    tx-checksum-sctp: off [fixed]
scatter-gather: on
    tx-scatter-gather: on
    tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
    tx-tcp-segmentation: on
    tx-tcp-ecn-segmentation: off [fixed]
    tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
busy-poll: on [fixed]
hw-tc-offload: off
I am wondering why the privacy-flags only show the flow-director and nothing more??
root@ubuntu-cg:~# ethtool --show-priv-flags $dev
Private flags for ens4f0:
flow-director-atr: off
virtual-functions are enabled
root@ubuntu-cg:~# virsh nodedev-dumpxml pci_0000_81_00_0
<device>
 <name>pci_0000_81_00_0</name>
 <path>/sys/devices/pci0000:80/0000:80:01.0/0000:81:00.0</path>
 <parent>pci_0000_80_01_0</parent>
 <driver>
  <name>ixgbe</name>
 </driver>
 <capability type='pci'>
  <domain>0</domain>
  <bus>129</bus>
  <slot>0</slot>
  <function>0</function>
  <product id='0x10fb'>82599ES 10-Gigabit SFI/SFP+ Network Connection</product>
  <vendor id='0x8086'>Intel Corporation</vendor>
  <capability type='virt_functions' maxCount='63'>
   <address domain='0x0000' bus='0x81' slot='0x10' function='0x0'/>
   <address domain='0x0000' bus='0x81' slot='0x10' function='0x2'/>
   <address domain='0x0000' bus='0x81' slot='0x10' function='0x4'/>
   <address domain='0x0000' bus='0x81' slot='0x10' function='0x6'/>
   <address domain='0x0000' bus='0x81' slot='0x11' function='0x0'/>
   <address domain='0x0000' bus='0x81' slot='0x11' function='0x2'/>
   <address domain='0x0000' bus='0x81' slot='0x11' function='0x4'/>
   <address domain='0x0000' bus='0x81' slot='0x11' function='0x6'/>
  </capability>
  <iommuGroup number='55'>
   <address domain='0x0000' bus='0x81' slot='0x00' function='0x0'/>
  </iommuGroup>
  <numa node='1'/>
  <pci-express>
   <link validity='cap' port='0' speed='5' width='8'/>
   <link validity='sta' speed='5' width='8'/>
  </pci-express>
 </capability>
</device>
I tried the below commands to get it fixed:
root@ubuntu-cg:~# ip link set dev $dev vf $vf trust on
root@ubuntu-cg:~# ip link set dev $dev vf $vf spoofchk off
root@ubuntu-cg:~# ethtool --set-priv-flags $dev vf-true-promisc-support on
ethtool: bad command line argument(s)
I thought that the --set-priv-flags "vf-true-promisc-support" should be the solution, somehow the command fails when trying to execute it.
Any pointer how to proceed here very much appreciated.
If promisc-mode for the vf is not the right approach, kindly let me know.
OS is ubuntu 16.04
many thanks
christian
Caguicla_Intel
Hello cgraf2,
Kindly provide the following details for us to check on your query.
1.) Exact model of your adapter. You may share the PBA number of the adapter so we can double check on the model. Please refer to the link below on where to find the PBA.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-io/ethernet-products.html
2.) Kernel version information.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
Caguicla_Intel
Hello cgraf2,
Good day!
Please provide the requested information for us to check on your query. Just in case you have additional questions and clarifications on this matter, please let us know.
Hoping to hear from you soon.
Crisselle C
cgraf2
x520-pba.pngDear Crisselle,
thanks for your help. Please find the info below:
Last login: Thu Oct 31 08:35:46 2019 from xx
lab@ubuntu-cg:~$ uname -a
Linux ubuntu-cg 4.15.0-66-generic #75~16.04.1-Ubuntu SMP Tue Oct 1 14:01:08 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
lab@ubuntu-cg:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:  Ubuntu 16.04.6 LTS
Release:    16.04
Codename:    xenial
The PBA if I read it correctly is: G93555
many thanks
christian
Caguicla_Intel
Hello Christian,
Thank you for the reply.
Please allow us to check on this. Rest assured that we will provide an update within 1-3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello Christian,
Thank you for the patience on this matter.
After checking, please be informed that unicast promiscuous mode is not supported in Intel 82599 VFs. We would suggest to submit a feature request on sourceforge through the link below.
https://sourceforge.net/p/e1000/feature-requests/
Let us know if you have additional questions and clarifications on this request.
We look forward to hear from you.
Crisselle C
cgraf2
Dear Criselle,
many thanks for clarification on this matter. I understand its not supported.
We can close this one here - thanks alot
christian
Caguicla_Intel
Hello Christian,
You are welcome.
As advised, we will now proceed with closure. Thank you very much for your patience and kind understanding on this matter.  Should you have any other concerns or assistance needed in the future, feel free to post a new question.
Crisselle C
