Ethernet Products
5823 Discussions
Can I get the ULP enable/disable utility?
APalm3
I work in IT at a corporation where almost all of our current computers have the Intel Ethernet Connection l218-LM network adapters. I have seen 5 computers in the last 2 months come up with the error where this network suddenly stops working and produces Error Code 10: this device cannot start. I have searched high and low for a solution, and the ULP enable/disable utility is the only thing I haven't tried yet. Can someone please send the utility to me?
Hi Nicodemus609,
Thank you for posting at Wired Communities. I sent a private message to you.
sharon
CSmit29
https://downloadcenter.intel.com/download/27489/ULPEnable-Utility ULPEnable Utility Available for Download
Download Link: https://downloadcenter.intel.com/download/27489/ULPEnable-Utility ULPEnable Utility
Overview
ULPEnable Utility is used to Enable/Disable Ultra Low Power feature for I218 & I219 network connections.
ENABLE - Enables the ULP (Ultra Low Power) feature of the I218 Network Connection
DISABLE - Disables the ULP (Ultra Low Power) feature of the I218 Network Connection
ENABLE - Enables the ULP (Ultra Low Power) feature of the I219 Network Connection
DISABLE - Disables the ULP (Ultra Low Power) feature of the I219 Network Connection
Supported Devices
Intel® Ethernet Connection I218 Family
Intel® Ethernet Connection I219 Family
