I encountered an issue as described in the subject field and discovered that Intel does not officially support this Ethernet controller on Ubuntu 18.04.6. Are there any alternative solutions to this problem?
Hi JChen6,
We see that you are using Intel Ethernet controller I226-V With the OS Ubuntu 18.04.6.
Please share the Serial number of the server or the device on which you are using this Ethernet controller, and was the controller working fine previously?
Best Regards
Arun_Intel
